Our Community is 662,000 Strong. Join Us.
Why do B-Series smoke?
pvtcook
11-02-2006, 07:04 PM
Im thinking of buying a 93 Mazda. It smokes really bad when you first crank it. Ive noticed several of these trucks doing this. How do you fix this problem?
archer of loaf
11-07-2006, 10:38 AM
valve seals need to be replaced - a not too complex job... rubber gets old, then hard, then oil leaks...
Kyrasis6
11-18-2006, 02:43 PM
Can also be stuck or worn out piston rings, if you don't plan on a rebuild I would do both dry & wet leakdown and compression checks before buying. If either the leakdown test or compression check show improvement with a squirt of oil in the cylinders then it will probably smoke until you atleast re-ring the pistons.
