94 S10 4x4 Smog and Idle problems ,Please need someones help.cmr29sun 11-02-2006, 05:58 PM 94 S10 4x4 Zvin (if that matters) over 100,000 miles and trying (NEED) to get 6 more months out of truck Truck isn't maintaining a high idle and or has flucuating idle or so I was told by smog test place. Can't even take the smog test. Failing test would be progress. Truck runs well enough. I mean I'm not going to beat anyone off the line but it gets us from point A to point B with reliability. Military has us moving out of the country in 6 months and trucks not moving with us. I just need to get 6 months or so out of it. Did get the codes they are 107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input 117 Engine Coolant Temperature Circuit Low Input 123 Throttle/Pedal Position Sensor/Switch A Circuit High Input 139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2) 300 Random/Multiple Cylinder Misfire Detected Took it to shop. Asked if O2 gone bad would give idle problem was told affect idle yes but not enough to have an aborted smog test. Told shop I don't want nor can I afford to fix even half of everything that truck needs fixing. Two days later they say O2 wire toasted on exaust and sensor burned out. $90 to find this out which is fine but the $210 to repair it and $59 for them to then try and smog test it not so fine. I can get free retest from place that gave it the aborted test. On top of that I see in my future this as a first attempt of many to get me the 15 minutes decent idle to just take smog test. I'd be happy to pass or fail. They them selves said they didn't believe it was cause of idle problem when I dropped it off to them. I want to try to fix what needs fixing to get codes cleared myself. What kind of job is replacing O2 sensor. Don't care how much of a pain in the butt it is cause when your done your happy you didn't pay someone else to do it for you. So what do anyone of you reading this think I should be picking up at the Autozone ? O2 sensor or does someone else have another suggestion. Please please any knowledge you can share would be appreciated beyond belief. The sooner the better my time on temp plates has run out. cmr29sun maxwedge 11-02-2006, 08:12 PM A 7/8 box wrench usually will suffice to access most o2 sensors, sometimes a special slotted socket is necesssary but I think you can use the box wrench. The other codes are another issue. I don't think this will fix the idle issue that sounds like a bad egr or possible vacuum leak. Codes say possible bad temp sensor or connector, you will not pass a smog test with the other issues either. cmr29sun 11-02-2006, 08:55 PM Thanks for the reply. I saw autozone sold some special wrench or something for like $15. As far as failing like I said I'm out of time on temps and a failure could get me more temp plate time maybe (6 months would suit me just GREAT!). Right now doing all the work we can ourselves is the only option. Don't expect the O2 to fix all my problems. Truck isn't worth investing a lot of money in which is good because I don't have a lot to invest(lol). I definitely can't waste it on the labor cost of someone else doing the fixes we can do especially when it gets me no closer to simply taking the smog test. A test failure, well we will cross that bridge when we have to. Shoot change that, I'd like to cross it right now if I could. Thanks again for your reply much appreciated. cmr29sun blazes9395 11-03-2006, 12:25 AM Geez, this one sounds like a whole bag of problems. VIN Z and multiple missfire, when was the last time a tune up was done on this, cap and rotor, wires and plugs? If it was a long time and you want to limit the amount of money you spend, get some standard AC delco plugs, and at least a rotor and clean up you cap(assuming its not broken) and reinstall. Check the resistance on your plug wires, and if they are not bad, reuse them. The TPS, MAP and ECT (Engine Coolant Temperature Sensor) can be checked with a voltmeter, to see what readings are actually coming from those sensors. All thoses sensors going out is hard to believe. Probe those sensors and see what readings you get. If you find these sensors are in fact bad, and really want to keep it on the cheap side, go to a wrecking yard. Up here, and I am sure down there, these are so common and plentiful trucks, you could easily get all these sensors for next to nothing. Good Luck! cmr29sun 11-06-2006, 05:17 PM Thank you Blazes9395 for your reply. Would of got back to you sooner but we were changing plugs. Yes it has been a while since the last tune up. I had bought some Auto lite plugs a few weeks back but didn't get around to it. Saw you mention the AC plugs and saw a write up else where advising the AC plugs so I went and picked them up instead. Also picked up Haines manual to replace the engine fluid stained one we had. Ours had just sketches and no real pics so I thought it was worth the $16 for the Haines.We just visually inspected the wires and they looked fine. I haven't gotten it on the freeway yet but there does seem to be less hesitation. The plugs were pretty bad. The looked like the ash deposits pic on the back page of the Haines Repair Manual. Like I said it does seem like it's running different. I'm not sure if thats wishful thinking or the fact that I didn't think it ran to bad to begin with. I am headed over to the smog test place that tested (tried to) it before to give it another try. Oh by the way my Hubby did say that the man had told him that it was in fact on it's way to passing until the Idle problem. Whether it passes it or not I am going to be changing the O2 next weekend. Hubby doesn't exactly enjoy working on it but me I love it. Thanks again and I'll let you know how it goes ( keep your fingers crossed ). cmr29sun cmr29sun 11-13-2006, 10:39 AM Well Bad news didn't maintain the idle. I ran the thing for a bit before driving down to test place so it was warmed up. Was running fine far as I could tell. The guy puts it on the rollers and hits the gas. I couldn't hear from where I was but could see test screen change from the green box to red meaning it was flucuating speed. He tried more than once. After he gave up he let me in the garage and says "This is what your truck does.". Now I can hear it and it's idle would drop to where it sounds like it's going to stall out and then it revs then back to almost shutting off. It's almost as if someone were sitting behind the wheel giving it the gas just before it dies out. Now it was fine driving down to the place well wasn't doing any of this crap. The guy jumps back in while it's still running like crap and drives around to the front of the place to me. He gets out and it's idling normally. The almost stalling out followed but the little rev that keeps itself running is gone. So whatever the problem it's set off by him trying to maintain the high speed for the test, bad idle continues when he pulls off rollers and sets it into park then within minutes and driving a few hundred feet it adjusts back somehow to idling fine. Perhaps the truck doesn't like him or hates taking tests...LOL...I don't know. Like I said guy says it looks like it would pass until it does this and test gets aborted. Please anyone >>>help. We just got orders to leave the states in a few months and I couldn't even sell it for a $1 with no smog. Can't apply for a waiver because it's never been registered in Cali. I don't want to drive illegally with expired out of state tags in fact all my Cali registration fees are paid in full already just have to bring them the darn smog check. Please someone anyone.... Thanks for any help cmr29sun JoulesWinfield 11-13-2006, 11:51 AM Im gonna take a guess and say its your MAP sensor failure that is messing up the idle speed. I had that problem with a 1989 2.8 liter. After the MAP sensor it ran just fine. Thats my best guess. Maybe with some searching you could find a way to test the switch itself before you replace it. blazes9395 11-13-2006, 11:58 PM Another thing to take a close look at any vaccuum leaks. Take a close look at the TBI to intke gasket, and make sure its good. take a close look at the intake gaskets and make sure they are good. While it could easily be something like Joules montioned MAP sensor, again make sure this sensor has a good vaccuum source, and is not clogged, or disconnected from its vaccuum source. An easy way to make sure the engine itself is good, along with the intake and TBI gaske(s), is to first ground your diagnostics port(like you would when your getting codes, retrieving codes). Do this when the engine is hot, not cold. Wait 30 seconds, after 30 seconds, as its flashing codes, get under the hood and disconnect the IAC(idle Air Control) valve, (as its flashing codes) get back in , turn the key off, disconnect your code reader(or un-ground the diagnostis link). At this point start the truck. If it does'nt start give it a little gas while starting it. When it starts, if it doesn't idle properly by itself, hold the pedal at the proper idle, if it idles now properly, you need to adjust your idle. If it can't hold idle like this, or if it won't idle without you holding the pedal, you need to take a look at gaskets, or vaccuum problems. This test also takes into consideration at this point, there is no service engine light, and sensors such as the MAP, O2, TPS, Coolant Temp Sensors, are all working properly. Even though the emissions label under the hood says no idle adjustment is necessarty, the idle on a TBI engine can be adjusted, so the TPS sensor is at the proper reading with the throttle body. Good Luck! blazes9395 11-14-2006, 12:20 AM Another thing to take a look at now, while thinking about this is your ground cable. Take a good look at the battery cables, especailly the ground. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
