205/70/R15 Stock Size
Google
Web AF
jeev155
11-01-2006, 09:10 AM
I got a 97 lumina ls with 205/70/R15 Stock Size.
Essentially, i'm trying to get a wider tire for appearance purposes - keeping the 15 inch wheels
Has anyone has success with wider tires? Sizes would be great so I can test how much the speedo will be off [http://www.miata.net/garage/tirecalc.html]
Thanks in advance....
jeffcoslacker
11-01-2006, 09:40 AM
My '97 LS came with 225-60-16's which would probably stand about the same height as your 205-70's but are definitely wider.
I'm sure you could get away with 225 60 or 55 15's or somewhere thereabouts, so you could have the extra width without changing diameter enough to make a huge speedo error....
jeffcoslacker
11-01-2006, 09:44 AM
I just used that calculator, and a 245/60-15 (a legit size) would give you only a 1% error...
maxwedge
11-01-2006, 04:07 PM
Better get a wider wheel on there with those tires for proper tread contact patch.
jeev155
11-01-2006, 08:54 PM
On the stock 15 inch wheels, how far do you think i can push the width? 225/60/15?
tblake
11-01-2006, 09:41 PM
i have 235/55/16's on my 16 inch rims, and they dont rub anything.
Google
Web AF
