power window troublesmilemarker 10-29-2006, 05:49 PM Go ahead and get all the insultes and jibes in now, because this is a fairly assinine question. I just need someone to tell me where the fuses/circut breakers for the power window system in my 94 toyota corolla are. The're supposed to be in the drivers kick panel, but it is not so. Anyone able to help? moneybaby007 10-29-2006, 10:36 PM If your 94 is anything like my 95, the fuse for it is in the driver's kick panel, but it isn't a "normal" looking fuse. It's a type B or C fuse that looks like a cube and is about an inch or two above the other ones. I'm having issues with my windows, too. The driver's side window works, but the others don't. I thought it was a fuse but no such luck. If you have any tips, let me know. Good luck! milemarker 10-30-2006, 08:09 PM To Moneybaby007: was it one (or possibly both) of the two larger cubes directly above the two smaller, rectangular fuses above the main box? If so, do you know which one. The're a bitch to remove if you're not a romanian contortionist. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
