camshaft position sensorstangmach104 10-29-2006, 02:40 AM hey, I got a code for bad camshaft sensor, so I went out a bought a new one, but before i install it do I need to time the sensor or just put it in and start the car? And if I do need to time it how should I? The car is a 96 gt 2.4 5 speed xeroinfinity 10-29-2006, 09:14 AM You just install it. - Disconnect the negative battery cable. - Unplug the sensor harness connector at the sensor. - Unfasten the retaining bolt, then remove the sensor from the camshaft housing. To install - Place the sensor into position. - Install the CMP sensor retaining bolt, then tighten to 88 inch lbs (10 Nm). - Attach the sensor harness connector. - Connect the negative battery cable. Hope that helps! stangmach104 10-29-2006, 11:46 AM thanks for the help! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
