jack stand placementdesimunda 10-26-2006, 10:44 PM Hello all, i plan to do my front brakes this weekend. Is there a picture available that shows the best spots for jackstand placement once i have the corolla jacked up. the year is 1997. thanks xt477 10-29-2006, 08:17 PM dont have pix but there is a seam where 2 peices of frame come together just behind where you put the factory jack is where I placed mine. I pulled the transmission and did alot of tugging car seamed very solid. desimunda 10-31-2006, 12:48 AM dont have pix but there is a seam where 2 peices of frame come together just behind where you put the factory jack is where I placed mine. I pulled the transmission and did alot of tugging car seamed very solid. i will check it out..is it right behind towards the back or the inside towards the middle? KimMG 11-01-2006, 12:13 AM desimunda 11-01-2006, 06:47 AM http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/16/9a/a8/0900823d80169aa8.jsp i should have mentioned this before but i am using the OEM scissor jack. that was my problem i was jacking where i needed to place the stands! could i jack just beside where i am supposed to with the scissor and then place jacks in the notched out spots on both sides like it says in the picture? not sure.. KimMG 11-01-2006, 04:56 PM Some repair manuals show alternative locations for jack stand placement. Do you have a repair manual? You should look at a manual before working on the brakes. Modern cars have specialized instructions for bleeding and compressing calipers that do not pertain to older cars. Especially if you have anti-lock brakes. xt477 11-03-2006, 06:25 PM under the rocker panel? I have never seen anyone place a stand inder the rocker panel. Use the factory jack then look just behind there and you'll see the frame and place the stands under the frame. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
