Turn Signal Flasherdp5010 10-26-2006, 12:54 PM My 2000 Grand Am SE Failed inspection because the Left side turn signal flashed to fast. Right side is okay. Can I change the flasher? Where is it located? Thanks grfnkl 10-26-2006, 02:01 PM There is no actual flasher like the older cars has..... I would first Check your light bulbs, you may have one out causing it to flash faster. The rear has 2 bulbs in the lower compartment, and the front you have the one all the way by the front grill area and the one behind the orange reflector. All of these lights go on when the turn signal is turned on. If you are not sure put the 4 ways on the compare each side. IF by some chance that all the lights are working, the unit that control the flashing of the bulbs is actually controled through the hazard switch, so you would actually have to replace the entire switch. Good luck Jmoney3318 10-26-2006, 02:01 PM the reason its flashing could be because its indicating that your bulb needs to be replaced xeroinfinity 10-26-2006, 10:31 PM one of the left turn bulbs are blown. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
