No oil and nothing on driveway
Google
Web AF
marehaven
10-26-2006, 12:12 PM
I just took my '94 Towncar in to my mechanic. In the last month I have added 4 qts of oil to it. I have had the car a year ..... previous owner was a retired school teacher who bought it new and put 75,000 on it.
My mechanic says rings are shot so needs new engine.
I am a woman who knows squat about cars, but am always willing to try to research my options. Since the car runs like a top ....... I am thinking it must have an oil pump or something that we should check first. It is not leaking oil on the driveway and I have not noticed anything out of the tailpipe.
jtmerritt
10-26-2006, 02:02 PM
Probably a combination of rings and valve guides leaking oil into the combustion chamber to be burned. 4 qts of oil a month is a lot assuming you are driving an average number of miles. With the catalytic converter most of the time you won't see the oil burning coming out of the tailpipe so that isn't a good indicator. However, heavy oil burning will eventually ruin the catalytic converter if it hasn't already. 75K miles and needing rings is unusual but depending on how the retried school teacher drove the car and maintained it may have a lot to do with the problem. Get a second opinion and then go from there. An oil pump will not cause high use of oil unless it is leaking and since there is no visible evidence of an oil leak then it must be getting burned.
John :)
marehaven
10-26-2006, 02:56 PM
John ........
She took immaculate care of this car and had oil changed regularily. I drive it 20 miles per day to and from work and scoot around in it on weekends. It is not driven hard and was not causing any problems prior to this. Would not have known anything was wrong if the light had not come on.
Rings and valves, you say ....... isn't that an engine overhaul?
jtmerritt
10-26-2006, 03:05 PM
Yes rings and valves are pretty much a rebuild of the engine. 75K just doesn't make sense for high oil usage when the car has been treated as well as it has. 4 qts of oil in 1000 miles is very high, basically an oil change. These engines are usually good for at least 150K miles before they show the early indications of any oil usage. Are you absolutely sure you are not seeing any oil on the ground at all? Park the car over some cardboard when you park it for the night and see if you get any oil leaks. Have you had the oil and filter changed since you noticed the high oil usage?
John :)
jtmerritt
10-26-2006, 03:09 PM
I forgot to ask. How did your mechanic determine that the engine needed a new set of rings?
John
marehaven
10-26-2006, 03:25 PM
Nope ........ he said it need a new engine and transmission. $5000 worth. Is there a "sucker" sign on my forehead? I may be a woman, but I still think the problem is not that severe. I have no problems with power or compression or anything noticeable.
jtmerritt
10-26-2006, 03:32 PM
Have you had the oil and filter changed since you noticed the oil usage problem? Again, based on what did he determine the need for a new engine and transmission? This may sound like a dumb question but do you have reason to trust this guy? Is he your regular mechanic and has he been reliable and fair in the past? Does he have a good reputation?
John
marehaven
10-26-2006, 03:38 PM
I am in a small town and this guy is pretty reliable. He has an oil change shop and does not do this kind of repair. In fact, after putting two quarts of oil in it last night and driving 30 miles ..... the dipstick was dry this morning when he went to change my oil. I went in for an early oil change and to see what his opinion was of the situation. I have an appointment with the guy who normally does auto repair for me next week.
Somebody suggested I take it in to an AutoZone and have them put a computer on it. Does this older car have a computer in it?
Towncar
10-26-2006, 03:55 PM
Yep. It's OBDi compliant... it won't tell you much unless you've seen the CEL (check engine light) lit up on the dash panel.
I'm kinda with the other posters on this one...
The Town Cars are prone to Valve Guide SEALS drying out, cracking and leaking oil into the combustion chambers..
However, sucking two qts in 30 miles.. (did I read that right) you should definately see smoke from the exhaust pipes while accellerating.
Rings at 75k miles? I'm not going along with that one...
marehaven
10-26-2006, 04:26 PM
Is that a big deal like redoing the engine?
Towncar
10-26-2006, 04:33 PM
Let's wait to see what you get for a 2nd opinion next week.. Basically you have to remove the valve covers, get the cams out of the way, pull each valve spring, replace the seal under the spring, and put it all back together.
Valve Stem Seals are very cheap for a complete set, it's the labor that'll kill you.
Figure about $45/hr for 6 hours. Some shops changes a flat rate for a job.. so they may look at the big chart >> Valve stem seal replace = $500...
Have a look >> here (http://images.google.com/images?svnum=100&hl=en&lr=&safe=off&q=Valve+Stem+Seal&btnG=Search) << , you'll get a pretty good idea what they look like and where they fit.
marehaven
10-26-2006, 04:35 PM
Is it driveable if I keep oil in it??
Again ..... thanks for the info you guys are giving me
marehaven
10-26-2006, 04:39 PM
Steven .....
Thanks for the link ... found it interesting. Would I be smelling hot oil with this problem ... seems like I should ...... but have not noticed it.
Kim
Towncar
10-26-2006, 04:51 PM
You would smell oil if it's leaking onto the engine, then burning off. Otherwise you won't smell a thing.
When you drive, and accellerate hard for a small duration, say 20mph to 60mph with it floored... do you leave a smoke trail behind you?
Yes, you can drive if you keep oil in her... just don't run out :nono:
marehaven
10-26-2006, 05:08 PM
I forgot to add this part ..... the oil light would come on when starting the car and stay on for a minute or so until I drove it. It has never stayed on constantly to indicate low oil. It was like it came on until oil started really moving around inside there.
Just gunned it in the driveway and no black smoke. Will take it for a spiz later and see if it smokes when I accelerate hard.
JustSayGo
10-26-2006, 05:15 PM
I suspect that your PCV system is plugged. If you are not already aware, take a look at "How Stuff Works" You will find simple language and pictures that explain just about anything you want to know. Valve guide seals can crack and turn into little oil pumps on each valve stem that suck oil in and push oil down the valve guide as the seal flexes with the valve stem moving the seal like a bellows pump.
jtmerritt
10-27-2006, 03:22 PM
Thirty miles and nothing is showing on the dipstick. You are losing oil at an unbelievable rate, more than I think a car could actually burn in 30 miles. What has your experience been since the oil change yesterday. Also, the fact that the oil light comes on when you first start the car indicates a low oil pressure problem. Not necessarily due to a low oil level unless it is really low. I am wondering if maybe you aren't having a leak at the oil filter that is causing the oil loss and also the low pressure. But since you aren't seeing any oil drips kind of kills that theory. That is why I am asking about how the car is doing since the oil change yesterday. Is the cooling system showing any signs of oil which would indicate a head gasket leak?
John :)
marehaven
10-27-2006, 03:28 PM
I have not driven it today but did test that PCV valve and am finding a build-up of oil around that. It checked out ok but wondered if that PCV vakve grinnet us replaceable. I have not moved the car since yesterday. Almost afraid to, but think I will later. You know, a leak in the oil filter crossed my mind once. Haven't used the ac ...... it's been cool and damp here in Missouri. Will let you know what transposes after I take it out again.
Kim
jtmerritt
10-27-2006, 03:33 PM
No not the AC the engine coolant in the radiator. Have you noticed if the coolant/antifreeze in the overflow bottle is dark rather than a green or yellow color indicating that oil is getting into the cooling system, which can happen if there is a leaking head gasket.
jtmerritt
10-27-2006, 03:37 PM
I forgot to add that some oil around the PCV valve is normal since it is drawing crankcase oil vapors from the engine galley. If the PCV sticks or is faulty it can start to pull excessive amounts of oil to be burned in the engine. Go ahead and have that replaced since it isn't expensive and if it is faulty it can cause problems.
marehaven
10-27-2006, 03:43 PM
Just ran out and checked it ...... darkish green
rhandwor
11-13-2006, 09:17 PM
Are you checking the oil yourself I'm aware some garages short stick people.
They don't push the dipstick in all the way then they use an empty can and charge you.
You need to check the oil in the morning yourself. Add enough so it is clear full then check it daily extending time if it is ok.
Some plugged pcv's or other engine vents will suck oil out of the engine.
Scrapper
11-14-2006, 02:45 PM
the return holes under valve covers might be plugged and the oil isn't getting back down in oil pan...that is way to much oil as they are telling you..because if you have a cracked ring the spark plug should be fowling out on that much oil...
GOOD LUCK TO YOU....
Google
Web AF
