Wiper problems
Google
Web AF
mwebb188
10-25-2006, 09:14 AM
Ok i have a 2001 Lumina wipers started going up and down only 3 inches on high, I have replaced the wiper motor, wiper control motor, wiper switch, and even the handle that u turn and i still have the same problem, I replaced the motor twice hoping i got a bad motor but thta wasnt the case. If anyone can be of help i would greatly appreciate it
maxwedge
10-25-2006, 03:58 PM
Welcom to AF. How about the control circuit board? This is on high only?, also check all the grounds.
mwebb188
10-25-2006, 04:19 PM
Ended up replacing the circuit boards and a dealer motor and that did the trick, aftermarket motor wasnt makin contact with the circuit board, but now the low, high, and mist works but i have no delays. Anyone have any suggestions on why the delay is not working now
maxwedge
10-25-2006, 07:47 PM
Again the circuit board is part of the delay control, also the stalk of course.
mwebb188
10-26-2006, 07:38 AM
stalk?
maxwedge
10-26-2006, 08:00 AM
Sorry, signal lever/ sw. assy.
bobss396
10-26-2006, 11:35 AM
If the stalk still has the "clicks" working it is probably ok. I find that most aftermarket parts generally are crap, stick with GM/Delco parts wherever possible. I'm going through my 2nd Napa washer/control unit now and will at least try to replace it with an Aamco or Trico unit.
Bob
vicslic
06-29-2009, 05:39 AM
99 lumina-200k mi: have a similar problem with delay and low, high runs ok, and washer liquid gives it 4 swipes ok. replaced the turn signal sw which corrected my brake light problems, but no go on wiper issue. where is the circuit board located?
sbriar
06-30-2009, 12:05 AM
I went through 3 wiper motors on my 96 Lumina, I think the trick is to not tighten any thing down to tight that may cause the motor to bind up. on my third replacement I made sure the bolts were barley tighten and it has worked now for 2 years.
Google
Web AF
