h22a in my 93 accord, advise pleaseadrenealinedin1987 10-21-2006, 02:17 AM I am wanting to put an h22a in my accord i have done a lot of reasearch online and i want someones opinion and advise whe has actually done this can anyont tell me what i will actually need to do the sway and is it hard? the only thing im confused about is the ecu and wiring part lol. i think i know what to do but some advise would be very appritaied :1zhelp: also a buddie has a 97 civic he also wants to put an h22a in and i know that h22a civic swaps are a little more complicated does anyone have advise for us? how does the swap work out and is it hard? please any advise helps! JustSayGo 10-21-2006, 02:59 AM I transplanted an H22A and manual trans into a 91 Accord that had an auto trans. I spent a little time modifying motor mounts. Buy the motor mounts that fit H22A to the Accord body. The wiring harness modification and complete step by step engine swap are available on line at no charge. Auto transmission axles are longer than manual transmission axles and cause the suspension to bind. The H22A fit between the left and right frame better than the engine and auto that came out. I wouldn't say it was too much more difficult than replacing the engine same for same. Solder the wires and use shrink tube. Your friend is looking at a lot more work and body modification and suspension modification to handle the much heavier engine. adrenealinedin1987 10-21-2006, 02:59 PM ya i knew that the civic was going to be more work, would it be easier to buy a jumper for the ecu? im just trying to find the easiest fastest way without cutting the wiring harness any ideas JustSayGo 10-22-2006, 02:43 AM I am not familiar with an ECU jumper adapter harness. I think you may still need to learn how to solder and shrink (tube). Sounds like the jumper would be one giant easy step buy will double the number of potential bad connections at the ECU. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
