auto belt tensionersmfrancies 10-19-2006, 07:27 PM What does the auto belt tensioner have to do with my air conditioning? I was told that my tensioner burnt up because of the compressor problems with my air conditioner? Is this right? I am trying to make the connection! wrightz28 10-20-2006, 10:35 AM The tensioner, by reference of it's name, keeps tension on the serpentine belt. If a pulley (a/c in this case) locks up or goes out of alignment, it puts strain on the tensioners pulley. A bad tensioner will lead to belt failure and charging problems. To the same effect, I have seen where alternators go bad on a serpentine setup and shortly after it's been corrected, and if the A/C compressor is horizontal from it, the A/C clutch goes bad. Tensioners are fairly easy to replace based on their location and obstructions. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
