The noise no one can find!Norm Robinson 09-07-2002, 06:48 PM The second of my two perplexing problems with my 1990 735iL: the noise no one can find. This is one of those "every once in a while" noises. Here is the scenario: usually from a dead stop...as I begin moving there seems to be a sound much like the one the playing card in your bike spokes used to make when you were a kid. It sounds like it's in the right front. It increases/decreases with the speed of the car...nothing to do wioth increased/decreased RPM of engine. No change when the transmission shifts. SOmetimes it last 15 seconds, other times a couple mjinutes...but it always goes away after a short period of driving. Two different mechanics have looked for loose "things"...but, of course, the sounds never happens for them. Any suggestions would be appreciated. Thanks. schifrin 09-09-2002, 01:28 AM Had that same noise on a '92 735iL -- intermittent, but usually after sitting, idling a while in park, and then going back into drive. If it persisted more than a few seconds, I restarted the car, and it always cleared up, leading a few of us to believe that it was ignition related -- probably a wire heading south... Never got a chance to resolve it, though. PsyGrafx 09-15-2002, 04:53 PM I had a similar problem on my '92 E32 and it turned out to be that the differential was locked. Replaced with a rebuilt diff and the noise was gone. GRENADE TEETH 10-16-2002, 02:52 PM Same thing happens to my 1990 735iL. Scares the hell out of me every time. jcarey 10-21-2002, 11:43 AM Norm, The post on diff made me think of my '88 E32 whihc started making a very odd noise from stop and in slow turns that I called a grinding noise. Sounded like gears to me but could sound liek a card on spokes to others? Turns out that BMW non slip diffs require specific oil compared to the non-slip dif. If you have ahd the rear end lubrication oil changeds they may have used the wrong type and this caused mine to make an awful noise until I had ti drained and filled twice to flush it out with the porpre stuff. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
