Replacing a T-25 what do I need?
my97blackgst
10-17-2006, 10:04 PM
Hey It;s been forever since I posted on here. But I need some help real quick. I am replacing my T-25 with another one (just my wifes car..no need to go fast) Is there anything I need to replacing when swapping out turbo's? Any kits? Suggestions of any maintence items to look at while I am under there? Anything special advice from your experiance would be awesome!!! Is there a installation guide for me to read? I have never messed with my turbo so any advice would be appreciated. Thanks
defiancy
10-17-2006, 10:22 PM
The turbo gasket and 02 housing gasket would probably be good to change. You could also replace the turbo bolts if they are messed up at all.
Blackcrow64
10-17-2006, 10:25 PM
The only things you should need is the new turbo and I'm thinking there might be some crush washers on the oil lines... Can't remember for sure when I took my t25 off and sold it...
Either way, its relatively simple. You will lose a little bit of oil out of the turbo and you will lose a good bit of radiator fluid. So be sure to either drain the radiator first or be ready to plug the water lines with something. I haven't seen any guides on here for replacing a stock t25 yet... That would certainly be a good writeup that we need/could use.
**EDIT**
Oh yeah, and any gaskets that you remove should be replaced too.
**EDIT**
Thor06
10-17-2006, 10:56 PM
Ha ha, fuck new crush washers! I reused that shit god knows how many times I had the oil/coolant lines off the car. Seriously though, it would be good to replace them, I am going to when I do the rebuild this spring. So yeah, gaskets, crush washers, and turbo bolts. Those fuckers are not fun when they break off.
TeamRedLine23
10-17-2006, 11:34 PM
dont forget to change the oil return gasket. dont lose any bolts. take the fans out for more to work. the first time I took my turbo off I lowered the turbo and took it our from under the car. I think it was a lot harder then taking it out from the top.
