1985 Chevy Van clanks when initially startedpetef 10-17-2006, 08:39 AM 1985 Chevy G20 Van - Clanking sound at startup 305 Engine Automatic Trans. Over the past few months if vehicle is not run for more than a a day I was getting a repetitive clanking sound for the first 10 to 15 seconds that the engine was started. It sounded like it was coming from the rear of engine or maybe the exhaust pipes. I recently discovered my automatic transmission fluid was down about 2 to 3 quarts. Last time I checked it was about 8 moths ago. After refilling it, the clanking sound at startup has decreased dramatically but it still clanks a couple of times when initially stating the engine if the vehicle has not been run for a day or so. Once the vehicle is in use and I restart it, there is no clanking sound. I'm also noticing a slight vibration when driving that seems to be related to the drive train. I can feel the vibration in the whole vehicle and in the gas peddle. Vibration is worse when going uphill. What do you think is the problem? Am I doing more damage by driving with this slight vibration? In other words, how urgent is it that I get this fixed? ---pete--- bobss396 10-17-2006, 12:31 PM This could be a tough one to diagnose, but here goes. Check your motor mounts and transmission mount. Just for the heck of it, see if the exhaust is hitting anywhere too. Make sure that your starter, transmission to the block bolts and torque converter are all tight. A loose converter will clunk, but for a short time and would be consistent regardless of how long it sits. If it was that low on fluid, filling it up could lessen the noise. My $$ is on a loose torque converter. Bob petef 10-17-2006, 04:36 PM A loose converter will clunk, but for a short time and would be consistent regardless of how long it sits. If it was that low on fluid, filling it up could lessen the noise. My $$ is on a loose torque converter. That makes good sense, Bob. Perhaps the torque converter makes more noise when fluid is low because it's off balance partially filled and this condition is much worse when the fluid level is very low. A loose torque converter could also account for the vibration I'm experiencing. I'll open the cover under the torque converter and look for loose or missing bolts. Thanks. I'll let you know what I find in the next day or so. ---pete--- bobss396 10-17-2006, 09:45 PM Check for a cracked flex plate as well, just thought of that. Once you pull off the inspection pan you'll get a better idea. Bob jveik 10-18-2006, 09:06 AM maybe there's a cowpie stuck on your driveshaft petef 10-18-2006, 04:55 PM Hey Bob, You were right! I removed the dust pan to the torque converter and found 2 of the 3 bolts loose. I tightened the bolts and all is back to normal. No more vibration or clanking. I'm very happy. Thanks for the advice. ---pete--- bobss396 10-18-2006, 09:53 PM Alrighty, one in a row for me. Glad it was something simple, but keep an eye on it. The flexplate holes and/or bolts may have some wear compromising their holding power. A little loctite on the threads might be all it needs if it happens again. Bob petef 10-19-2006, 07:48 AM Alrighty, one in a row for me. Glad it was something simple, but keep an eye on it. The flexplate holes and/or bolts may have some wear compromising their holding power. A little loctite on the threads might be all it needs if it happens again. I can't keep my eye on it so easy, but I'll keep my ear on it. :) If it lossens again, I'll hear that clanking sound and I'll take that as a sign that the bolts are streteched and no longer have the holding power needed. I'll then go buy some brand new bolts from the dealer. Thanks again! ---pete--- 463 02-05-2007, 10:35 PM I had to fix the same thing on a1976 gm 3/4 ton. convertor nut and bolt fell right out into into the flywheel cover. i could just here a tinkel when i shut the truck off. a quick fix with no damage. factory screw up. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
