Transmission fill plug problem
ABigWeaney
10-15-2006, 10:52 PM
OK i got the bright idea to change my transmission fluid.... nothing ever goes as planned... OK so it has a really big bolt to drain the fluid and it was ez to take off and a lot of fluid pored out and i waited until it was finished draining and i put the bolt back on then i tried to take the fill plug off and it wouldn't even budge.. so i put a 4 ft break-over bar on it and it stripped out :banghead: .. so is there an ez way to get it out?
i have a 92 talon turbo..
Blackcrow64
10-15-2006, 11:11 PM
Stripped off the head of the bolt? If so, stick some vice grips on there and get it out. If that don't work then just drill a hole down the center and use an easy-out bit to get it out of there and put a new plug in. Messed up the threads too? Just use a tap and make it the next size bigger and run the proper size bolt in it...
Hope that helps ya out some.
TeamRedLine23
10-17-2006, 03:40 PM
you are really good at making things seem so easy!! lol
Blackcrow64
10-17-2006, 06:22 PM
lol It really is easy. Yet when it comes time for me to actually do it I seem to run into other problems. Can't find the drill, break a bit, grenade a grinding disc, etc... You know, all that fun stuff. Thats just my luck though. lol
