98 grand cherokee
ratchetgmc
10-13-2006, 07:28 PM
I am trying to remove the driver side lower marker light assembly to remove moisture inside. Believe I can remove if I remove side marker assembly. Can`t figure out how to remove though. With hood open can see small torx screw on top of side marker; and it appears that I can barely make out a screw on the bottom just above the bumper. But have no clue how to remove this bottom screw. Thanks for all the help I have received on this forum.
jeeperphil
10-13-2006, 07:52 PM
Use a long small diameter screw driver-philips if I remember. Flashlight helps also to look between light and bumper to locate screw. A little patience and time you will get it. Also use a good driver. Mine was a little tight and if I had used a worn screw driver I would have stripped the screw. That would have screwed me! good luck
