Brake warning light issue
aavp96
10-11-2006, 09:07 PM
93 PA
The Brake warning light comes on periodically when I turn or slow down.
Mostly when I turn to the left.
The brake pads and shoes are in good condition, fluid is at max level.
I suspect one of the brake sensors may be shorting out.
Is there an easy way to locate which sensor has a problen?
Or is there any other possible cause for this?
Thank you for your input.
wrightz28
10-12-2006, 10:33 AM
Which light, yellow (ABS) or red(base system) ?
aavp96
10-12-2006, 07:07 PM
The Red Warning light keeps coming on.
I was hoping to work on this issue on this weekend.
So all advise is welcome.
wrightz28
10-13-2006, 11:25 AM
Only sensor I could think of would be the fluid level sensor.
Any fault in the wheel sensors would tip the ABS light.
The red would indicate a either a fault in the standard hydraulic system or active praking brake.
