A few things for my 94 parkave
CVMòóse
10-09-2006, 09:45 AM
first the struts in the back of my car are shot and so is the compresser, so can i put stuts back on the rear that were ment for a buick without air ride or do i have to put air ride struts on and get the compresser and all that fix as well (ie leave it broke cuz i dont have that kind of money)
seconed dose and one know if a compant makes euro style tail lights for my car
and can somone please give me a link to a place where i can find a trailer hitch for my car.
also dose any one know of a performance chip for my car
Cntrysthbst
10-09-2006, 08:59 PM
You can find chips left and right on eBay. Seems these are already powerful engines.
This is just my advise but if your looking to put a hitch on your car I'd stay with the air shocks in the rear, which means replacing/fixing the comp., air shocks, and/or lines.
Euro lenses for the rear --- No ideal. Someone else may post on that. Good luck
Alibi
10-09-2006, 09:55 PM
I agree that if you are going to do any towing, you ought to leave the air shocks. Otherwise, replaceing the rear shocks with normals has been done in the past with success.
As for the rear lights...I've never seen any other than OEM. The aftermarket community just doens't have enough interest in these "granny cars" to produce nifty toys for them.
CVMòóse
10-10-2006, 07:09 PM
i was looking mo for a plug and play chip or tunner from supperchips or somthing like that
Bassasasin
10-11-2006, 07:59 PM
I wouldnt put a performance chip in a car you plan to tow with.. unless you had it programmed to shift a little earlier to help the engine.
CVMòóse
10-14-2006, 01:10 AM
towing is the exact reason that i wanted achip beacuse the car is compleatly gutless and has no poower and can barley make it up the hill somtimes with a traill with a 3 wheeler on it
jdq
10-16-2006, 02:36 PM
If that is the case, you have other problems need fixed that a chip wont fix.
Bassasasin
10-17-2006, 05:32 PM
TOwing?.. No supercharger I hope.. book says NO TOWING.
I know the chip can change where you shift.. perhaps you want a lower shift speed and sacrifice MPG..
CVMòóse
10-17-2006, 05:34 PM
no the car runs fin its just that im used to a 95 with 205hp not 170 and i want the hp increes because of teh typr of driving i do responding to call for teh fire dept
Cntrysthbst
10-19-2006, 10:07 PM
It seems like you have a combination of things you'd like from this car, I don't think you'll get all one them. I would figure on the most important to you and go with that. These cars weither it is an Ultra or not, are fast period. A supercharged with Grand tourning susp. sounds like what you want the most but you can't tow with it. The regular susp. (dynaride) doesn't handle as well as the Grand touring, which means you can't turn a corner as fast but you can tow with it. Hmmmm dont know where I'm going with this. Hope it helps.
CVMòóse
10-20-2006, 02:37 PM
i have a base modle not an ultra so the charger is ouit of the question im just looking for that little extra power to help the car in 3rd gear witch as any one whos ever "driven" a park ave like mine knows is when the car tends to down shift and be frairly indecisinve as to whitch gear it wants.
Bassasasin
10-20-2006, 04:52 PM
IN that case your all set.. order a performance chip..
Good Luck
CVMòóse
10-20-2006, 05:17 PM
i know..... i just cant find one for my modle year of car i can find them for 91-93 and 96 and up
CVMòóse
10-22-2006, 09:38 PM
found a chip at car stuff.com for a 93 but will it work with a 94
