ABS Light
Google
Web AF
krzykjn
10-06-2006, 12:41 PM
I have a 1996 Z71, can't get ABS light to go out. Tried to check codes, all I get is no data from computer.:frown: Any help would be appreciated!
bigrockk
10-06-2006, 02:17 PM
Not sure if this will help ,but it may. I did a search under this forum and the link below points to the results.
http://www.automotiveforums.com/search/?domains=automotiveforums.com&q=C%2FK+ABS+Light+&sa=Search&sitesearch=automotiveforums.com&client=pub-2911997839133131&forid=1&channel=3573406237&ie=ISO-8859-1&oe=ISO-8859-1&flav=0000&sig=xj2sALBGxv03Twmd&cof=GALT%3A%23008000%3BGL%3A1%3BDIV%3A%23336699%3B VLC%3A663399%3BAH%3Acenter%3BBGC%3AFFFFFF%3BLBGC%3 AFFFFFF%3BALC%3A0000FF%3BLC%3A0000FF%3BT%3A000000% 3BGFNT%3A0000FF%3BGIMP%3A0000FF%3BLH%3A50%3BLW%3A2 02%3BL%3Ahttp%3A%2F%2Fwww.automotiveforums.com%2Fi mg%2Flogo_s.gif%3BS%3Ahttp%3A%2F%2Fwww.automotivef orums.com%2Fvbulletin%2Findex.php%3BFORID%3A11&hl=en
maxwedge
10-06-2006, 02:47 PM
You need an abs function scanner for these codes, or check the wheel speed sensors at the sensor connector, should be about 1000-1220 ohms.
Blue Bowtie
10-07-2006, 10:30 AM
I'm guessing that this is the Kelsey-Hayes RWAL system instead of a 4-wheel ABS, correct? They are a bit different.
Google
Web AF
