Jetta rear wheel drive conversionPharty012 08-27-2001, 04:48 PM anyone know what the cost of a rear wheel drive conversion on a jetta would be??? trying to do my studies before i get the car and preparing my list of goodies to get... Evster3_16 03-24-2002, 05:02 AM I know people that are into drag racing, and have heard them talk about converting cars into rear wheel drive. It is possible to convert a car to rear wheel drive, but it requires alot of work. My guess is that it would be rediculously expensive. Not only that, but FWD cars have a transverse mounted engine, RWD cars have a longitudinal mounted engine. You'd have to rotate the engine, and possibly get a new trans. I'm not sure if a new trans is needed, but i don't think the current engine/trans. setup will convert easily. I'd have to say that it is possible, but I wouldn't have a clue on how to do it. I'm no expert so you should probably look into it further. I think that a RWD Jetta would be amazing, but I sure don't have the money/resources to do such a thing. HayaiCivic 07-10-2002, 11:28 AM Unless your kidding, dont waste your time. Jettas are FF for a reason. The entire car has been engineered for FF or pulling force. Pushing force will upset its balance. Your looking at around 20,000 dollars worth of custom equiptment and modification to the Jetta to run it in FR. If its worth it to you... personally, Id just buy something with FR so you dont have to be your own engineer. ;) Deakins 07-10-2002, 02:11 PM Get a 4-motion :) HayaiCivic 07-11-2002, 11:27 AM 4 wheel drive burns alot more torque per wheel, but I dont know about any real advantage over FF. Screamnwheels 01-10-2004, 10:55 PM Call me nieve, but wouldn't it just be as easy as using parts from a Audi A4 Quattro. Aren't the chassis' of the Jetta and A4 the same??? iamwhatiam 06-04-2004, 01:43 AM im doing the same with my golf i think it isnt as cooked up as everyone thinks it to be especially if your doing it yourself and that 20000 dollars is outrageous all it is is just a rear axle mounts shocks springs umm maybe some adjusments to the body to make the trans fit into the area other than that i cant't think of anything else to do for it JTrujillo86 06-04-2004, 02:56 AM Dont you need a new transmission? How is it possible to use the stock transaxle to run RWD?? Jeremy riceaterSLC 06-04-2004, 01:43 PM 4 wheel drive burns alot more torque per wheel, but I dont know about any real advantage over FF. the advantage of awd over FF is that you have a lot more usable contact patch for the drive wheels. if you are into 1/4, awd launches are a lot better than fwd. when you launch a car, the rear end squarts. in a fwd car, this reduces the load on the front wheels, therefore decreasing the traction. if you have awd, even if the front wheels lift, you still have some power goign to the rear wheels to help launch and keep traction. not to mention is is hella fun to have an awd car in the snow. Call me nieve, but wouldn't it just be as easy as using parts from a Audi A4 Quattro. Aren't the chassis' of the Jetta and A4 the same??? no, the Mk4 platform, Golf, Jetta, TT, and Audi A3 are the same. the Audi A6, A4 and VW Passat are all B5 platforms. Dont you need a new transmission? How is it possible to use the stock transaxle to run RWD?? yes, you do. depending on what mk vw you have, you can either do 4 motion or syncro, the older setup on mk2s. in general there are 2 types of awd trannies. 1) the type that are in DSM's. it attaches to the motor like a FWD tranny, but has an extra output for the rear wheels. the center diff. attaches right to the tranny and the driveshaft runs back to the rear diff. 2) the type that are Subaru's. it looks like a RWD tranny, but has two output shafts for hte front wheels right on the tranny. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
