New battery, now AC is stuck on Defrost, no VentTxBU 10-05-2006, 07:25 PM Like I said above, it's not the knob being stripped and not turning. Any ideas? 2000CAYukon 10-05-2006, 09:48 PM Like I said above, it's not the knob being stripped and not turning. Any ideas? What year is it? Could be that the actuator is worn out. //2000CAYukon TxBU 10-05-2006, 10:47 PM 2003 rhandwor 10-08-2006, 03:17 PM Mine has a dial on the right you turn to change they have many vacuum lines on the back. They are $57.00 at the dealer. If you pull it out it has contacts as you turn it. I would check they have proper tension and clean the surface with contact cleaner or brake clean. The plastic piece comes out with a screwdriver be very careful and don't break it. Then unbolt the unit so you can get to it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
