I Found It (idle Problem)
Mikelb
10-05-2006, 07:44 AM
DAMN.... (sry to start the thread off that way, but if you went through everything I went through to figure this one out, you'd say it too)
I'm gonna keep this short...
I had a terrible idle...
checked vacuum lines
no boost leaks
nothing loose
tested IAC
Reset ECU
Adjusted BISS
blocked EGR
and several weeks later...
my CEL came on... I looked at the AFC(while cruising), and noticed the throttle was sitting at 0%.... I floored it... didn't change...
I popped the hood, and realize that the TPS had come loose...
I reconnected the TPS, the idle immediately fixed itself...
Apparently it had never been fully connected...
I noticed that there is supposed to be a metal clip on the harness to hold it in place... this clip is missing... anyone know where I can pick another one up?
P#?
part name?
Thanks...
no boost leaks
nothing loose
tested IAC
Reset ECU
Adjusted BISS
blocked EGR
P#?
part name?
Thanks...
