Cutouts or duals
Google
Web AF
Mr. Luos
10-04-2006, 10:33 PM
Alright....
Seriously considering this option right now.
I have true duals that are non-mandral bent through magnaflow mufflers. High powered N/A 402ci. Makes 523 RWHP through that current exhaust and a 9".
Anyways...I know there is more.
My biggest problem is that the duals fit so tightly through the torque arm bracket that it bangs at idle. Sometimes pretty bad. Cam is a little big so the exhaust rocks with the lope.
This is what I am considering...
Running duals 3" cutouts about 12" off each collector, then running a single 3" pipe to that back through the same mufflers.
Not really concerned with HP numbers on the dyno...but I am concerned about track numbers.
Discuss please!!!!
Nate355RS
10-04-2006, 10:58 PM
Pros:
Should flow better and gets rid of the rattling.
Cons:
Tamer sound for daily driving.
I say go for it. If you don't mind what are the specs of your cam, I've been wondering for a while?
Mr. Luos
10-04-2006, 11:05 PM
248/254 at .050
629/622 lift
113 LSA
2.2 Straight six
10-04-2006, 11:19 PM
Straight-through sidepipes!
Morley
10-04-2006, 11:56 PM
With those HP numbers I'd be more worried that going back to a single 3" might put a restriction on the engine and cause fuel/air flow problems on the upper end. If you go that route, only use mandrel bends, keep the radi of the bends as large as possible and avoid 90* bends where ever possible. That will help keep restrictions to a minimum
Mr. Luos
10-05-2006, 12:00 AM
Of course it would cause a restriction. That would kinda be some of the point. A tamer street set-up then open the cutouts for track, dyno, etc.
Not worried about performance with the cutouts closed.
stone_mound_camaro
10-05-2006, 06:43 PM
just cut it off at the headers man! or where the crayon stops melting
92zcamaroperson
10-05-2006, 11:54 PM
i have always liked the true duals with an x pipe that dumps before the axel. You just have to have the ground clearance for it.
Mr. Luos
10-06-2006, 12:06 AM
That is fine and dandy if I didn't have the rear cover of a Trans Am.
Dumps is fine with a Camaro, but the Trans Am has the cover made for exhaust tips.
Should have the cutouts ordered by Sunday.
92zcamaroperson
10-06-2006, 12:11 AM
yeah i guess you're right
Morley
10-06-2006, 01:35 AM
I'm not referring to performance loss, I mean loss of driveability. Every exhaust system has some restriction, we're talking about restriction to the point where it severely affects the engine's ability to breathe. Now, if you had a skimpy 2.25" dual exhaust on it and were to go to a 3" single you'd actually see gains in exhaust flow. but if you have dual 2.75-3", you are going to suffer a loss going to a single 3", hard to say how much though.
Savage Messiah
10-06-2006, 03:32 AM
You've got HP Tuners right? is the exhaust bang bad enough to cause false KR?
Mr. Luos
10-06-2006, 08:27 AM
At idle we think it has.
Savage Messiah
10-06-2006, 02:58 PM
yea that's what I figured... that's bad lol
cutouts
NoRiceHere01
10-13-2006, 05:28 PM
i dont have a lot of experience with late model camaro exhaust but i have seen many different combos in magazines and many remain a single exhaust even with extreme engine configurations.i cant see a single 3" being a big issue, thats a big pipe.and if im not mistaken isnt one side of the tailpipe a straight thru, not passing thru the muffler?
karll
10-15-2006, 08:57 PM
are you going with electric or manual cutouts? just curious.
88camaroproject
10-15-2006, 09:15 PM
if you do get cutouts dont get the ones with the wingnuts, get like the cable operated or electric ones. more convienent(sp?) and you can just flap em open when ever, like if you race on the street ever. like a honda rolls up thinking your stock and takes off you flap em open and he shits his pants and gets served on a silver platter with the apple and everything.
viperh
10-15-2006, 10:03 PM
If you don't mind me asking what kid of motor mounts do you have I'm assuming with the 402 your running a urathane setup. What about dual 2.5" out the back then step it up to 3" past the Torque arm bracket (on the tunnel or on the 9" by the way?) That way it'll flow good and when the exhaust gas starts cooling down to expand it'll be in the 3" pipe. Also Mandrel Bends will open it up and help the flow You could run that through the mufflers and If you wanted the tru duals you could set that up in the pipes. Just expanding your options.
Nate
Mr. Luos
10-21-2006, 12:48 AM
Sorry to respond so late.
I have decided.
Dual 3" cutouts are being delivered next week. Non-electric. The electric ones get clogged with carbon so I went basic.
Gonna cut down the duals to 2.5"....I think. Depends on the cheapest route to free up clearance with the current set-up.
Car should sound the same as it does now on the street...but maybe a touch quieter.
When the cutouts are open.....you can figure that one out. :lol:
88camaroproject
10-24-2006, 11:56 AM
are they the cable operated cutouts or the ones you have to go under and thake the wingnuts off?
Mr. Luos
10-24-2006, 09:57 PM
I have to take them off.
No biggie, I didn't want the electric ones anyways...they get clogged with carbon.
I have paid for the cutouts...but dude is wasting my time with the shipping.
Savage Messiah
10-27-2006, 11:53 PM
electronic ones not only will carbn clob but the motor will burn out turning it into a manual one anyway... so good call there
Mr. Luos
10-28-2006, 06:50 PM
They will be here next week.
Shipping was an error in the UPS system I guess.
Hoping they show up Thursday...I will drop the car off that night if that is the case.
Meaning next weekend there should be a little open header video clip up. :lol:
Mr. Luos
11-02-2006, 07:40 PM
The Trans Am is at the exhaust shop. :icon16:
goldz28
11-02-2006, 09:37 PM
Can't wait to see it!!!!
Mr. Luos
11-02-2006, 10:21 PM
Friend has a stock catback.
Thinking about putting that on.
Tame sound and no banging for street use.
Mr. Luos
11-03-2006, 07:37 PM
LOL
Wow.
Nate355RS
11-03-2006, 08:09 PM
Mr. Luos
11-03-2006, 08:28 PM
Imagine large cammed LSx 402.
Running open headers.
And there you go.
poormillionaire2
11-03-2006, 08:41 PM
I ran open headers on my bolt-on LT1 and it sounded like a monster. After the first time I drove it, I lost some hearing. I can't imagine what a built cammed 402 LSx sounds like. I'm actually kinda frightened.
Mr. Luos
11-03-2006, 09:04 PM
Dyno time tomorrow. :lol:
Video to follow. hehe
Google
Web AF
