Black smoke = annoying
airFS
10-04-2006, 02:53 PM
Well, im really starting to get tired of the black smoke that is always coming out of the exhause. For example...whenever I warm up my car in the morning then come back outside about ten min. later there are always these black spots on the ground that come out of my exhaust. Also the one day when my friend was following me I stepped on it and he said this huge cloud of black smoke came out and sometimes I can actually see it in my rear view mirror. Please tell me what my problem is!!
Black99GST
10-04-2006, 03:24 PM
well the black spots on the ground are from condesation... and are usual. and the black smoke is from running rich... are you venting your BOV? this could be the cause for running so rich...:2cents:
airFS
10-04-2006, 03:54 PM
nope..my car has actually done this for a while even before I did most of my upgrades which is why its so annoying
nofear39427
10-04-2006, 04:07 PM
My 98 Dodge Neon did that all the time it litterally looked like a damn misquito truck.It had alot of blow back as well come to find out it was a bad piston ring well auctually all of them were bad.Thats why the cars blown up now.lol
So Check it out and see for yourself.Just trying to help.
airFS
10-09-2006, 11:16 AM
well, I think I finally found whats wrong, but I'm not shure how to fix it. I was looking at my stock intercooler and there was oil comeing out of the coupler on the end of the intercooler pipe. The oil is comepletely around it...please help!!
Turbodog97
10-10-2006, 10:10 PM
If it was oil it would have more of a blueish tint to it, it's most likely from running too rich or from some bad rings or valve seats or turbo seals or one of the above.
airFS
10-13-2006, 08:53 PM
How can I figure out which one it is??
gthompson97
10-15-2006, 01:52 PM
A leakdown test will tell you if you're rings or valve seals are shot, or a simple compression test will give you a little heads up as to what may be happening, but a leakdown test would still be better. The smoke is black and not more of a bluish right? Black means way rich on fuel=not so bad, blue means burning oil=bad.
airFS
10-16-2006, 07:16 PM
It's all black and only comes out under full throttle.
TeamRedLine23
10-17-2006, 03:05 PM
it could be your spark plugs. maybe. hopefully.
airFS
10-17-2006, 05:47 PM
I'll look in to it...should I get new wires too? I also recentley did my first oil change ever since I got the car and there was not a single metal shaving on the screw.
TeamRedLine23
10-17-2006, 05:51 PM
I always say if your gonig to do something, do it right. yeah you should get wires also and some NGK series 7 spark plugs if you are boosting more than stock.
ned032002
10-17-2006, 05:55 PM
Make sure that your not putting in too much oil because that too can damage piston rings and such and create monsterous clouds of smoke like I did in my Tercel.
TeamRedLine23
10-17-2006, 06:07 PM
:thinkerg: thats what I forget to mention ^
airFS
10-17-2006, 07:23 PM
I'm pretty shure I did it right because I measured out the number of quarts according to the owners manual and plus it was doing it before I changed my oil.
airFS
10-17-2006, 07:25 PM
which ones should I get??
http://www.extremepsi.com/store/customer/search.php?veh=2G+DSM&cat=268&type=Spark+Plugs
TeamRedLine23
10-17-2006, 09:00 PM
if you are running more then stock boost but less then 15 psi I would go with the one step colder.
airFS
10-17-2006, 09:27 PM
I'm running stock boost but I may increase it some time so should I still get them. Would they have any negative effect?? Do they increase hp at all w/ the new wires?
TeamRedLine23
10-17-2006, 09:42 PM
pretty much any upgrade you do to an ignition will help with performance. you may notice a slight difference over stock but chances are that you will not. upgraded spark wires just deliver more energy to the spark plug for a better air/fuel burn. Im pretty sure the one step cold on stock boost wont make a difference but i may be wrong so dont quote me on that. when do you plan on raising the boost on your car?
airFS
10-18-2006, 05:41 AM
not until next summer
gthompson97
10-18-2006, 09:39 AM
Then just run with the stockers for now, no need to run a colder plug. Go with the 6ES.
airFS
10-18-2006, 05:36 PM
One last question. Which wires should I get? Should I go bigger like a magnecor 8.5 or should I run something that's closer related to stock?
http://www.extremepsi.com/store/customer/search.php?veh=2G+DSM&cat=268&type=Spark+Plug+Wires
TeamRedLine23
10-18-2006, 06:18 PM
get the biggest you can get that is within your budget. bigger wires=more engery to the spark plus=a bigger and better spark=a better burn=better miles per gallon=saving money at the gas pump=more money for other parts....and most of all more horsepower!!! it really is a vitious circle.
airFS
10-18-2006, 06:42 PM
ok, I'll go with the magnecor's then
gthompson97
10-18-2006, 06:58 PM
The magnecores will really make no difference over your stockers if you're still running a stock car, they're overkill IMO. The only time that upgraded wires of that size are needed is when you need every last bit of spark to make all the horsepower that you can. Stick with some aftermarket stock sized ones to save a little $$.
airFS
10-18-2006, 07:17 PM
So your saying I shouldnt get those? Could you please pick one out from the link that I gave? It also dosent really matter to me how much they are either.
TeamRedLine23
10-18-2006, 08:39 PM
airFS, I thought it said you had a 16g turbo in your sig. thats why i said get the big wires. sorry about that. gThompson97 is right. i gave you bad info.. its an honest mistake.
airFS
10-18-2006, 08:46 PM
It's cool, but I still need to know which wires I should get
gthompson97
10-19-2006, 01:36 AM
The NGK's will be fine.
airFS
10-19-2006, 05:44 AM
Thanks guys...you've been a HUGE help
