engine pullyjr vw 10-03-2006, 10:01 PM I removed the bolt that holds the belt pully. But how do I remove the lower pully that is attached to the engine? The spot welds let go and the pully split in two. Rick's69 10-08-2006, 04:46 AM use 2 screw drivers and and pry it off its not that hard just keep at it jr vw 10-20-2006, 12:22 AM Thank you for the advice. but I ended up removing it wlth a slide hammer gear puller. where I had to rotate the pully half turns in order to pull it off evenly with a slide hammer. Powercoguy 10-21-2006, 12:53 AM Sometimes you just have to use what's laying around in the garage. Old VW's should never die. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
