Blend Air Door Actuator Part #
ferncreekjeep
10-02-2006, 01:50 PM
For 1996 Grand Cherokee Laredo (without automatic temp controls).
Symptoms include no heat or no cooling. The blend air door is stuck on cool or hot.
Old part # (part taken off): 16124922
New AcDelco part #: 1571845
- can be found at www.rockauto.com for about $35 + shipping
New GM part #: 89018356
- can be found at www.gmpartsdirect.com for about $33 + shipping
The actuator is located on the passenger side - tucked up between the wheel well and the hvac housing. It is mounted with two screws that are not that easy to remove - you will most likely need a right angle philips head screw driver. Just pull back the carpet a little, unlpug the electrical conection and unscrew.
Good Luck and stay warm/cool.
