89 K1500 tail lights wont light up
Google
Web AF
heavyredchevy
10-02-2006, 02:57 AM
The tail lights on my 89 k1500 wont light up anymore. The fronts work just fine, and I still have brake lights, and turn signals. They wont light up when I turn my lights on. Wheres the best place to start looking for a fix? The fuses are good.
Thanks
Blue Bowtie
10-02-2006, 09:49 AM
Remove the offending tail lamp assembly, turn it upside-down, remove the back-up light socket and bulb, and pour the housing full of Crown Royal or Canadian Club. If it's like the rest of us, it should be "lit up" in about ten minutes.
But seriously, check the grounds near the rear body harness, the ground strap between the truck bed and frame, and connections at the sockets themselves. A voltmeter is going to be very useful in the diagnosis. Don't be afraid to connect a length of wire from a good engine or battery ground to the tail lamp socket(s) temporarily to help diagnose the problem.
idmetro
10-02-2006, 01:58 PM
Save the Crown Royal for lighting up the mechanic after a job well done.
If the system is the same as that on an 86 a dual filament bulb was used; could be as simple as one filament burned out. I'd check that first before digging too deep. Secondarily you'll want to check if you have trailer wiring, in my case the prior owner did a very poor job installing trailer wiring and it had shorted, when rewired correctly (with good materials and care) all worked fine.
heavyredchevy
10-04-2006, 08:51 PM
Its not the bulbs, i got new bulbs when i replaced the buckets that they plug into.
777stickman
10-04-2006, 09:22 PM
"Blue Bowtie" Awesome response. No wonder you're "registered". I'm still wiping laugh tears!!!
Anyway, Redchevy: There's 2 contacts in each bucket. One's for turn and stop and one's for running lights. Get a volt meter and check for power on the contacts. If no power for the running lights then do as "idmetro" suggests and check the trailer wiring harness and plug in's. If you've got turn and brake lights the grounds are probably good as they go right from the bulb sockets.
Man, I'm still laughing. Good one "BLUE"............Steve
alblogg
10-04-2006, 09:23 PM
I going for a broke wire because if it was a ground problem it would be affecting the other lights especially the turn signals they act crazy when they ain't grounded good. So I like idmetro I would start with a test light or a volt meter at the socket and work my way back and be sure to look for any add ons or like he said check the point where a trailer might have been wired up. Work back until you find juice.
heavyredchevy
10-05-2006, 09:08 PM
I will let you guys now how it goes when i have a change to do it on the weekend. Thanks guys for your help.
rhandwor
10-07-2006, 03:30 PM
Check any plugs going back to the tail lights and clean with electrical cleaner or brake clean. Your hunting for corrosion.
heavyredchevy
10-07-2006, 05:01 PM
I took a little look at it today and the wire job that the first owner did on the trailer harness is just a complete mess. None of the connections that he made are portected by tape or anything. Its just bare wire. Im sure the connections to the buckets are fine, but ill double check them and let you guys know how it went when I get more time to work on it.
Thanks
heavyredchevy
10-17-2006, 12:15 AM
Just thought id let you guys know it was the trailer wire harness. The wires for the tailights, and the reverse lights were both completly disconnected. I took everything he did apart and re-wired/soldered everything w/shrink tubing on it, so it should hold up now. I cant beleave that the last owner thought a simple twist of the 2 wires and a little tape was going to hold it.
Anyways thats for your help.
Google
Web AF
