No power to rear wheels on my Bravada
negoshe8n
10-01-2006, 10:50 PM
OK I have a 94 with 217k on it! Runs like a top. I pulled the front driveshaft to do the ujoints and figured I could just drive it with the shaft off for the day. Umm.. got nothing to the rear wheels. No noise or anything ever came from the transfer case. What gives? Or gave I should say.
534BC
10-02-2006, 09:36 AM
Maybe it has a center diff? Those are full time 4wd ? right? If you look underneath the front yoke is spinning ?
alblogg
10-02-2006, 10:18 AM
Try putting it in 4 Hi and check your vacuum lines from under your battery box that run to your transfer case for holes or dry rot.
negoshe8n
10-02-2006, 03:03 PM
It's actually called AWD. No selector for the awd. The front yoke does spin. Just when I pull the front shaft the rear doesn't engauge.
alblogg
10-02-2006, 03:12 PM
Well now that's a kicker. I know on the old 4X4 full time the right rear and the left front pulled in 2 HI and you could take the drive shaft out of the front and run them but on the AWD and the day of the computer on board maybe that has something to do with it.
534BC
10-02-2006, 10:19 PM
It probably has a center diff of some sort and needs to have the front yoke stopped or hooked up. (If it does not have some sort of locker)
It is just like jacking up one wheel and seeing the other wheel not driving.
HotRodV6
10-08-2006, 11:12 AM
Well your Bravada has a BW 4472 transfer cae that has whats called a viscous coupleing inside that is a completely sealed and non servicable unit, so changing the oil wont help, its what splits the power for the AWD system,35% front and 65% rear, i have a 92 GMC Typhoon that has the same AWD system but with a turbocharged 4.3L V6, and mine has 163K miles and mine will do the same thing, basically you need to either find a new transfer case, get yours rebuilt, or get a good used one. BTW The viscous coupling can still be had new from GM for about 600 bucks, and then the rest of the transfer case can be rebuilt for about 2-300 bucks in parts.
