how do i reconize z85
Google
Web AF
loperbe360
09-20-2006, 11:00 PM
How do I visualy tell the difference between z71 and z85. I just bought a 4x4 colorado 3500 vortec and was told it was z71, but I can't verify that. If anyone knows, it would be a big help.
Thanks,
2eyefishclaw
10-03-2006, 08:18 PM
not 100% but I think the difference is in the suspension
16th hippy
10-16-2006, 10:15 PM
not the best at the trim types, but i thought Z-71 was for full size pickups only....and the Z-85 was the comperable type of off-road susp. for the colorado. please correct me if i am wrong, but like i said, not the best at trim types.
tri-power
11-11-2006, 08:39 PM
Z85 is the base model package. All of the Z71 models I have seen are labeled Z71 on the quarter panel. Hoewver this doesn't mean all are badged that way.
dcjredline
04-12-2007, 02:31 PM
Thanks,
Z71 usually has the wider fender flares. Best way to tell is look at your SPID tag I believe it is in the glovebox and look for Z71 or Z85 in the list.
tbuckit1
12-10-2007, 12:28 PM
The build sheet (sticker) in the glove compartment has ALL the build codes for your particular truck listed in alphabetical order.
It will state whether your truck is a Z85 or Z71.....probably in the second row of codes from the bottom. Every one of those codes means something unique to your truck, such as axle ratios to the type of radio.
drifttruck99
12-15-2007, 08:40 PM
if you bought it new then the z71 would sit a couple inches higher than the z85. the z71 is an off road package, larger tires etc. just because it doesn't say z71 doesn't mean that it isn't. Z85 is your basic suspension package. Z71 usually have fender flares and larger tires.
Google
Web AF
