White smoke from Engine!!
hawk2000
09-20-2006, 05:54 PM
I have a '97 Vilager with 120k miles on it. It has been problem free for the most part ( except for regular Brake jobs, routine oil changes and front right axle replacement) . Recently, the engine started to rev up and down very slightly and a week ago, there was white smoke coming out of the engine. Alongwith the smoke was the coolant boiling in the coolant reservoir. I let it cool down, refilled the coolant, since the coolant had boiled over from the container. I took the Van out for a short drive and checked under the hood and found the same white smoke coming out of the engine. Any suggestions on where to begin to troubleshoot?
mustangmike351c
09-30-2006, 08:59 PM
its a blown head gasket
KimMG
10-01-2006, 02:52 AM
Pressure test the cooling system to see if you can find any leaks. Some autoparts stores rent specialty tools. Supposedly there is a kit that you can buy at an autoparts store to test for exhaust gases in the cooling system. Exhaust gasses in the cooling system is indicative of a blown headgasket.
Do you have white smoke coming out of the tailpipe? Is your vehicle overheating?
hawk2000
10-03-2006, 12:31 PM
Thanks for replying. Yes, there is white smoke coming from the tailpipe. I figured it might be a blown gasket too.
