anyone had a shift kit installed during tranny rebuild?
Google
Web AF
rental blazer
09-18-2006, 11:12 PM
my tranny is pushing over 131k miles and i want to know the signs of a tranny thats wearing out...my other question will a shift kit greatly reduce wased rev's from the motor and help accleration what would a good shift kit do and act? any reccomendions and please again tell me the signs of a tired tranny that wants to die so i have ample warning time..btw this is a 95 blazer 4x4 w/ 4l60e with the car rolling off the assably line march 10 1995
silicon212
09-18-2006, 11:37 PM
If your transmission has high miles on it and it seems tired, a shift kit will polish it off, i.e. kill it. You need to rebuild the transmission.
blazes9395
The most obvious sign is the condition of the fluid. If its getting dirty and smells burnt fast - its time to start saving for a tranny rebuild. Other signs are delayed engagment when shifting gears, both when the transmission is shifting through its gear range when accelerating, or when you are actually changing gears with the selector. As the tranny gets hotter when driving, especially in stop and go traffic, if you notice any long shifts, usually a sign of a tired tranny. You have to remember that the shifting is controlled by the truck's powertrain computer, which, in turn takes many variables into consideration before a shift takes place(adaptive shifting). So shift timing, shift length can be different at different times.
The thing with trannies is unless there is a serious or obvious problem with the tranny, the tranmission can sometimes go for a long time without actually failing, or it could drop out on you the next time you pull out of your driveway.
When I did my tranny I used the sonnax sure cure kit, http://www.thesurecure.com/parts/parts/4L60-E(in).pdf, upgraded some internal parts to make the tranny more stronger. when it was done, it shifting quicker, less overlap, but smooth. Hope this helps.
Macgyver007
09-21-2006, 02:35 PM
I bought the Kit for my tranny and stopped into my local Trans shop and asked them to install it and he warned me NOT to. All you have to in most shops is mention 4L60E and they will get a big grin on their face. My trans shop and I am assuming most others know of the "valve body fix" for these trans. It stops the burning fluid and bad shifting. when mine was done it ran like brand new. Up to 280,000 Kms and counting.
Cost me under $100 and I waited while they did it.
Took em about 2 Hrs and bing bang boom, all like new
Google
Web AF
