checking low gas light
Google
Web AF
Jay97Rodeo
09-17-2006, 10:56 AM
Hello,
Kinda of dumb question, how do you make sure the low fuel bulb is working ? does it light up when you first start the car ? mine doesn't and I once ran quite low on gas (based on mileage) and it didn't light up. I opened the dashboard and the first bulb is labelled "fuel", opened it - it looked fine visually i.e no black burnt marks, no broken filament in the bulb itself.
just trying to make sure i covered my bases, so i don't have to make multiple trips to the store.
thanks
Jay97Rodeo.
amigo-2k
09-17-2006, 11:18 AM
Let see if we can get a couple of the the other 97-96 owers to post how much gas they put in when the light comes on ...
Canucklehead
09-17-2006, 12:45 PM
Let see if we can get a couple of the the other 97-96 owers to post how much gas they put in when the light comes on ...Never had the low fuel light come when driving but I can tell you that it doesn't turn on during the "pre-startup" lamp test.
Jay97Rodeo
09-17-2006, 02:23 PM
ok.. i wonder why it does not.
i tried to swap bulb from another indicator. all except the low gas light seem to be the same. (: I think, I will head to a store to get replacement bulb. Seriously , is there no way to test the low gas indicator without actually driving on a road and risk running out of gas ?
Canucklehead
09-17-2006, 03:10 PM
i tried to swap bulb from another indicator. all except the low gas light seem to be the same. (: I think, I will head to a store to get replacement bulb. Seriously , is there no way to test the low gas indicator without actually driving on a road and risk running out of gas ?Maybe I should have clarified my original reply. I have seen the light come on once. I had a little more than 1/8 of a tank or so while getting off of the highway and going around the cloverleaf-thingee I had it come on. It was below the "E" mark but as soon as I go going straight it went out. I'm usually pretty good about not letting my gas get much below 1/4 tank so I don't even care if it the light works or not.
isaac Sewell
05-01-2008, 11:15 AM
I have a 2001 Isuzu Rodio that at 1/4 tank the fuel light come on and the gas gauge come but i have a 1/2 tank of fuel can you help me
amigo-2k
05-01-2008, 01:21 PM
Your fuel sending unit needs to be replaced. It is a 40 dollar part that is located in the gas tank. See the FAQ's for more information.
Google
Web AF
