1995 Blazer A/C question. Is there a clutch relay?
Google
Web AF
Lith1um
09-13-2006, 06:47 AM
Hello all,
Is there an a/c clutch relay on a 4d 95 blazer? If so, which one is it?
Also, there is a diode installed in the harness leading up to the clutch. It's contained in a white crimp on connector kinda like a scotch-lock connector. It's approx 1 foot from the plug on the clutch.
One wire on the connector is marked with a y and one with an x. Could you please tell me which color wire corresponds with which letter? I removed the connector looking for a fuse link and I cant remember which wire goes where.
Thanks in advance!
sreve
09-14-2006, 06:40 PM
the relay is second from left on the firewall.
to find out which way the diode goes. with the comp. relay removed hook a test light to power. see which wire is grounded. block the path to grd with the diode.
Lith1um
09-14-2006, 06:52 PM
Thank you Sreve!
Google
Web AF
