HELP - Removing Rear Glass on a '98 S-10
syoung_2000
09-13-2006, 02:34 AM
Anyone know how to remove the rear glass on a '98 s-10? It is the solid glass, not sliding window if that makes a difference. Thanks in advance for any help! - Shawn
jhouser
09-22-2006, 06:44 AM
When I've taken glass out of other cars, I just cut away at the seal with a razor blade until it easily came out, should be pretty simple.
tom3
09-24-2006, 09:54 PM
Usually you can remove the trim around the inside, take your finger tips and pull back the rubber flap in a corner and push a corner of the glass out, then work from there. Not easy by any means but it can be done that way. And you'll save the molding.
