Squeeky Aveo 2005
Google
Web AF
ema
09-12-2006, 11:57 AM
Hi there....Myself and a co-worker have same problem with our 2005 aveos...have started a sqeeking noise that sounds to be in the suspension. They have replaced several things on his car already with no improvement. Mine just begun so I am asking if anyone else experienced this and actually had the car fixed. Appreciate your help......thanx.........ema:smile:
hayesbcajh
09-13-2006, 08:05 AM
There is already a post on this problem.
http://www.automotiveforums.com/vbulletin/showthread.php?t=381887
I'm taking my 04 Sedan in this morning...warranty is about to expire.
I will post the outcome in the original thread.
ddaru_chee
09-26-2006, 10:12 PM
Hey, my 2004 Aveo has the same problem, although it's not really bothering, I think it's quite normal, you can change almost every part of your suspension and that noise will still come out. So if you don't want to hear that noise, I suggest to put more isolator behind your firewall and your front fenders. It can also reduce the noise from your tyres.
ema
09-27-2006, 09:24 AM
Thanks for reply..I always had junk that made such noises and was content...but when you buy new you kinda expect better.Since I first posted my problem I have had the car checked and even had the rep hop in the car to hear it too. They changed the ball joints and bolts for lower control arm. Now she is less noisey...but there is still a little something there.
She is only 1 yr old and they even had to replace adjuster nut in the headlamp twice...I blind the driver in front of me because the light moves direction.....I think they got socket stripped...next time I am demanding replacement. ................. ema
Google
Web AF
