Another headlight victim...PLEASE HELP!FlashGordon07 09-11-2006, 08:45 PM :banghead: I have read similar posts to my sob story...but mine's different enough to ask y'all if I have a bigger problem here... I have changed the lightbulbs on my 2002 Xterra about 3000 times now. I get the one headlight on, one off. I get the one headlight on, one off plus the high beam indicator. Now I have them both off. Driving in the dark is kinda hard... PLEASE HELP what do I do?! I've changed the bulbs and everything works for a few days or a few weeks and then it all turns to s**t again... Any help would be REALLY appreciated! FixUrNissan 09-19-2006, 11:24 PM I would start with checking bulbs .. No changing them .. switch to see if one works in one not the other. Witch could indicate and electrical issue. Where you would need to check Voltages and resistances in wires to see if that is all good. If you had tried higher amp bulbs Headlight connectors could melt and cause shorting of bulbs. If you have any more questions feel free to ask GL... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
