1990 Grand Am.. Having some slight issuesdunk4u2 08-29-2002, 12:25 AM I have just recieved a free 1990 Grand Am. However, I am having a slight problem with it. When it gets above 65 mph the car seems to shake. There is no problems at any speed less than 65. There really isn't that much loss of control of the car but I have an idea it is just an alignment problem. Could that be what it is? or Possibly a motor mount for the car? I ask because I have never had this situation happen before with any type of car that I've owned so I am pretty much green to this whole thing. Any insight would be greatly appreciated. 95GrandAmSE 03-06-2003, 07:37 AM Hope you are still checking for answers... I had the same problem. Turned out that the left half axle was slightly bent. A non-dealer shop replaced it for a total cost of about $400 if I remember correctly. That fixed the problem. Smooth sailing since. bw_654 07-02-2003, 05:36 AM sounds stupid but check your rear tires. if the bands are broke they can do that. Flatrater 07-02-2003, 07:22 PM I would suggest getting your tires balanced first! Any tire problems might be caught while balancing. 95GrandAmSE 400 seems high to me! It should only be 1 hour of labor and you can buy whole axles for less than 100 dollars at most parts stores! messylildude 01-12-2004, 09:36 AM I just got the same exact car and I had the same problem, and had to replace the lft front wheel baring, got new tires, and it still does it up to about 72 mph, so I'm going to take it this payday and get the allignment. But thats what it sounds like to me, Allignment, however, you would want new tires before you did that, and yes, They would have to be ballanced. adoodas 01-15-2004, 07:55 PM i had the exact same problem on my 94 GA and i just got it aligned and its been a sweet ride since. they can just check the alignment b4 doin anything and see how outta whack it is. sounds exactly like what happened to me and i think replacing the axle or some shit is a garage taking u for a run. C_Sephiroth 01-15-2004, 10:22 PM Usually an Alignment will not cause a Vibration unless There is something bent. I.E. Axle Shaft. Flatrater is right 1st Step have The balance checked on your tires, and have them look everthing over, for loose parts or tire issues. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
