Turn Signals
Google
Web AF
SIKO
09-09-2006, 01:09 PM
Turn Signals Won't Blink. Bulbs Are All Ok. Is It The Turn Signal Switch?
SIKO
09-09-2006, 01:11 PM
Turn Signals Won't Blink (RIGHT OR LEFT). Bulbs Are All Ok. Is It The Turn Signal Switch?
Flash75
09-09-2006, 02:42 PM
Try a new signal light flasher. It may help if you tell us what your car is.
Clifton
SIKO
09-10-2006, 01:21 PM
1979 Mgb
Flash75
09-10-2006, 04:54 PM
Thanks, The signal flasher unit is the place to start, I should have said signal flasher in the above post. If the flasher is good it's possible the hazard switch needs replacing or cleaning. You can check for a hazard switch problem by jumpering from terminal 7 to terminal 8 on the hazard flasher switch with a test lead. If the jumper clears the problem the hazard switch is the problem. Usually a turn signal switch wouldn't be bad in both directions. You may need a wiring diagram and something to check voltage, a cheap multimeter or a test lamp. Wiring diagrams can be found here. http://www.advanceautowire.com/
On the left click on stock schematics, then MGB. You will need the Late US Market MGB From Haynes diagram. These diagrams are in color and easier to follow than those in Haynes and other publications.
Google
Web AF
