annoying clunk
Google
Web AF
fastGTP01
09-09-2006, 11:22 AM
well i tore my car apart the other night and i checked everything. cv joint good, strut good, inner and outer tierod good, lower ball joint good, control arm good, bearing good. any other ideas because im completely stumped, thanks.
richtazz
09-09-2006, 11:45 AM
I assume that the clunk happens while turning by the parts you've already checked? Check the rack and pinion mounts/bushings, rack input shaft bearing, lower steering column shaft or bearing and the cradle/subframe to body mounts.
fastGTP01
09-09-2006, 06:41 PM
yea, at first i thought it was the rack, but the only prob with that is when you put your ear up to the wheel to listen, the sound is comping directly from the center of the wheel, and the only time you can physically feel a vibration is when you put your hand on the rim itself. its very weird.
dblthebass
10-25-2007, 12:05 AM
def. sounds like a bearing shot just because it doesnt have side to side or up and down play doesn't mean its not bad but i would also check out the strut mounts
Google
Web AF
