93 master cylinder noise
hollerg
09-08-2006, 01:14 AM
The master cyl went out (went all the way to the floor). I had a rebuilt put in. Afterwords, the brake pedel was not as high off the floor as before. Seems to stop okay, but when I press a little harder at the stop light, I hear a squishing sound as the peddle sinks lower, but not all the way to the floor. Is this master cyl working correctly?
I don't remember hearing it before, but I may not have been listening for it. What explains the squishing sound?
KimMG
09-08-2006, 02:20 AM
You may have gotten a defective rebuilt. It sounds like it is leaking internally. Did you have a shop install it?
drdee1342
09-08-2006, 03:33 AM
have you bleed the brakes anytime you change a master cylinder you need to bench bleed then bleed the brakes!!
shorod
09-08-2006, 06:20 PM
Yep, make sure person who replaced the master cylinder bench bled it first, then bled the braking system.
-Rod
