318i Rumbling front end HELP!!DanSnipez 09-04-2006, 07:33 AM I need some expert help from anyone out there i have recently bought a k reg 318 and it has a weird knocking sound from the front end when going over bumps or hitting the brakes hard over uneven ground which makes it not very pleasant to drive:banghead: , i have checked wheel nuts sus mount bolts etc but wondered if there was a common fault or somewhere to look/investigate. All help is really appreciated:) Thanks Dan Gearhead202 09-06-2006, 07:46 PM r u sure it is coming from the front because i had the same problem with my 91 318is i changed the rear shock mounts and it went away. Mouglie 09-07-2006, 06:09 AM probably your wheel hubs... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
