PO 300 & popping in cat.y2kblazer 09-02-2006, 11:22 AM I have a 2000 blazer "W" eng. Have only a PO 300 code per Autozone. Started slight miss a couple weeks ago & now gotten much worse. Stopped by Autozone & they checked codes . Showed only a PO 300. Now it's popping in the cat. converter. Swapped dist cap & rotor -no difference. 3-4 mos ago, did intake gaskets new cap & rotor AC delco plat plugs wires thermostat cleaned MAF fuel filter also now it's running VERY rich checked most sensors with vom per Haynes OK maybe injector o-rings?? thanks for any help or other ideas ZL1power69 09-02-2006, 05:39 PM i would say 1 (or more) of your o2 sensors may be going bad. another posibility would be a leaking injection spider. Blue Bowtie 09-02-2006, 06:42 PM Have you check the fuel pressure regulator? I't no fun on the CPFI system, but it could be leaking. One indiciation is to test running fuel pressure, then see if it drops off quickly after engine shut down. FWIW, there are no 'O' rings on the injectors in that system - It sues the central injector pod and "poppet" stlye injectors buried in the intake runners. http://72.19.213.157/files/CPFIInjectorAssembly.jpg Checking standing fuel pressure would be a good idea anyway. y2kblazer 09-03-2006, 12:22 PM fuel pressure is: turn key on- 62 psi. key off- drops to 50 in about 2 seconds. while running- guage swings from approx 45 to approx 58 VERY fast- in almost a blur... prob regulator? rlith 09-03-2006, 06:50 PM Sounds like the regulator or the injectorrr vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
