98 4x4 Front End Roarkingfishracin 08-31-2006, 05:00 PM I have a roar coming from my front end that gets louder as I increase in speed. It sounds like Im riding on 44" super swampers. I replaced the right front wheel bearing about 6 months ago but this sounds different then the wheel bearing. Where should I start looking? :banghead: muddog321 08-31-2006, 05:17 PM Fan clutch could be frozen or locked on full - so if that open the hood and check to see if thats it. kingfishracin 08-31-2006, 05:34 PM Just checked the fan. I could spin it freely so I guess thats not it.:frown: amtech4 09-21-2006, 03:59 AM Could it have something to do with your encoder motor? Mine failed some time ago and I would get that exact same sound (intermittently). It would quit when I would put it into 4 high then back into 2X. Cloud Strife 09-21-2006, 09:21 AM Well check the left wheel bearing. Also you may want to look at your brakes possible seizing up just slightly enough to be making noise. 98blazerRI 09-21-2006, 10:13 AM I am having the same problem same sound. Just went through the entire front end and replaced everything from Ball joints to pitman arm... Now I am getting a moaning noise... I figured it was wheel bearing.... Blazer is perfectly streight.... Let us know how you make out... ericn1300 09-21-2006, 08:23 PM Just checked the fan. I could spin it freely so I guess thats not it.:frown: it should turn freely with the engine off. when you start the engine the fan clutch will engage and cause a roaring sound for a second or two then shut off. check to see if the fan is turning after a few seconds with the engine stone cold. jimarch40 09-21-2006, 08:42 PM I have a 96 S-15 Jimmy and had a similar noise coming from the front end. Originally it was thought to be the bearings so those were replaced but that didn't fix it. Ended up having to put a new (well used) front differential end and then the noise went away. Not cheap either. Might not be your problem but might give you something to have checked out. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
