1987 crown victoria
gigglesnirt
08-28-2006, 02:34 PM
im wondering how much i can tow with this car its got the 5.0 engine i plan on towing a single axle trailer with a kart on it probably 1200lbs at the most, will it be safe?
drwolfenstein
08-28-2006, 03:36 PM
should be soem info in your owbers manual on GPW i would think you would be okay, if anything may need some air shocks.
junk yard doggie
08-28-2006, 09:22 PM
She should pull just fine. The air shocks would be a good idea. I would also install a trans. cooler just to be on the safe side.
Mike
Mike
drwolfenstein
08-29-2006, 10:07 AM
shouldn't that already have a trans cooler??
Dondo
09-20-2006, 11:16 PM
A 1987 Cv with a trans cooler in front,, and a class 3 hitch is able to 3000lbs ,, and with a weight equlizer system can handle up to 5000 lbs !! But do not tow in OD !! and if your going to do heavy loads I would add some air shocks in there on the rear
