1992 LeSabre noisy ride !?!jfranklin 08-24-2006, 01:44 PM My 1992 LeSabre (155k) makes a sound like a small prop airplane while driving down the road (30mph and higher). I thought it was the front tires which where worn so I changed them. But the noise persists. The noise goes away when i'm turning right or left but comes back when I straighten out. Are my wheel bearings shot ?! Is this tough job for a DIY mechanic? Thanks John corning_d3 08-24-2006, 02:40 PM It sounds like a wheel bearing. Grasp the wheel/tire at the 3 and 9 o'clock positions and rock it back and forth. Not so much as to turn the wheel, just "feel" the slack. jfranklin 08-25-2006, 12:30 PM Thanks for the response There is very-very little slack in the front tires and none in the back Also the sound I am hearing is very uniform and seems to be coming from the front end corning_d3 08-25-2006, 01:28 PM Hmm, it's still possible you have a dry/flatspotted bearing that hasn't developed any slack just yet. If you decide to change it, it can be done with regular hand tools, but you'll need a huge socket to fit the axle shaft nut. grcore 08-25-2006, 06:54 PM yes, sounds just like a wheel bearing. Generally if the pitch changes when you rock the steering back and forth while you are rolling along, that is what it is. if the pitch didn't change, I would suspect the cv joint. Loekee75 08-26-2006, 05:51 AM I also agree with a wheel bearing worn. These come as a hub assembly jfranklin 08-29-2006, 07:12 PM Thanks for the responses I have some new info about my dilema to add I had a friend drive with me to listen to the sound and he said it was coming from the front passengers side loudest I also looked at the front passenger side tire that I took off (when I changed the front tires) and saw that it was very warn on the inside of the tire Could a warn bearing cause abnormal tire wear ? Are my tires out of balance ? Would that make the noise I'm hearing Thanks corning_d3 08-29-2006, 10:47 PM A badly worn bearing can eat up tires.. You could have a bad tire, also. How hot does the drivers side rim get compared to the pass side one? jfranklin 09-08-2006, 12:42 PM After further examination from a mechanic friend of mine, the sound coming from the passenger front end he was pretty sure was that of a worn bearing and after feeling the hub after a test spin it was found to be very hot. So the final diagnosis is a worn bearing, so off to Advance I go Thank you for all the responses ! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
