vat
Google
Web AF
bigtoe555
08-20-2006, 09:19 PM
2005 avalanche want start trying to find the vat on it
bigtoe555
locknkey
08-21-2006, 12:05 AM
Go see your local Locksmith.
bigtoe555
08-21-2006, 06:18 AM
i would like to know where the vat is locate on my 2005 avalanche it trys to start be it dies out the was in a flood and i have work this for two week replaceing parts and to get it to start everything is ok the computer is ok
thank you for the help
bigtoe555
locknkey
08-21-2006, 08:05 AM
I doubt the transponder would have anything to do with a flooding problem, if the battery has been discharged, the 2005 model would have to be reprogrammed has thats the way it was designed. The transponder controls the fuel shut off sensor. It will have to be reprogrammed with dianostic equipment no matter what to clear the error codes that has been in the computer since the flooding. This model doesn't have a VATS system. It uses a 10 cut key whereas the vats system uses the 6 cut gm key. On your key shank will be a + or a circle + near the bottom of the head. This is the Transponder Key. The GM small 6 cut key uses a small resistor inbeded into the key. These are the VATs keys. You will need to take both of your remotes to the company to have them reprogrammed to the truck. The Locksmith is a cheaper way to have this done if they have the necessary equipment, however a GM dealer would be able to repair any OTHER problems that is related to the flooding, such as dirtly sensors, water in the gas tank, filters and so on. Even the ejectors and TBI could be effected by water, including any electrical connections in the firewall/fusebox. Good luck.
gquinn
06-03-2007, 05:24 PM
Typically is the passkey 3 uses resistance in the key cylinder. The security light will be flashing if not reading correct signal
MT-2500
06-05-2007, 11:53 AM
bigtoe555
You need to get a good engine/body capable scanner on it and see where the problem is.
If there is a problem there should be a code set in the anti theft or body or engine pcm/vcm that will lead you to the problem.
Has the battery been changed or gone dead or weak?
Some of them you can reset the anti theft system.
Check owners manual for instructions.
MT
Google
Web AF
