blazer ignition modules?
philman97401
08-18-2006, 11:18 PM
is there a common problem with blazer ignition modules overheating and failing because of heat issues?
BlazerLT
08-19-2006, 01:08 AM
what is your problem and what year?
philman97401
08-19-2006, 09:11 AM
I have a '98 blazer. I was wondering if others have had problems with the ignition modules overheating and failing because the engine bay gets too hot.
BlazerLT
08-19-2006, 02:47 PM
Not normally.
Why are you asking?
Why are you asking?
534BC
08-20-2006, 11:03 AM
One thing is sure (if the module is the thing on the coil) It looks similar to the HEI ones. Without the paste it will fail very quickly.
philman97401
08-20-2006, 11:27 AM
my catalytic converter plugged up and then the ignition module failed. seems to me that the physical location of the ignition module -- above the catalytic converter would make it sensitive to heat issues. btw, the honeycomb collapsed inside a brand new converter installed by mr goodwrench. mr good wrench doesn't want to warranty claiming the ignition module to fail.
534BC
08-20-2006, 11:43 AM
Hmm, I didn't realise they were that close. Mine is on the coil on top of engine. I supose some exhaust heat can go up there at a stop, I don't think that is why the module failed.
