1998 Isuzu Rodeo AC not engagingelopez2 08-17-2006, 10:20 AM Guys Had a ? about AC I got this Isuzu Rodeo and AC Doesn't work. When ever I jumper it from relay AC compressor kicks in, try changing relays but no luck. What else should I check? What's the relay connected to does anybody know. Also guy from work told me to check filter from AC not sure what he was talking about. Gizmo42 08-17-2006, 03:58 PM http://i30.photobucket.com/albums/c337/Gizmo420/AC1.jpg What is not mentioned in there is the high pressure and low pressure switches. High pressure shouldnt be a problem since it hasnt run. If there is low/no refrigerant then the low pressure switch will open and keep the clutch from engaging. elopez2 08-18-2006, 04:22 PM Thanks Dave I will try checking system for low freon will need to jumper compressor to check pressure. Thanks again! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
