help!
View Full Version : help! help! Graphik Styles 08-20-2002, 01:48 PM ci5ic 08-20-2002, 09:07 PM Okay, all transparent images are .Gif's. They are called "Transparent Gif's" (go figure :rolleyes: ) also known as "Gif 89a" format Anyhow, all you gotta do is choose "export" then "Gif 89a Export" from the file menu. Then select the setting you want and hit OK. Then give it a name and BAM! boingo82 08-20-2002, 09:30 PM Like Ci5ic says, jpeg doesn't support transparency. The only web-friendly formats that do are gif89a and png. Graphik Styles 08-21-2002, 03:30 PM thanx for the help BeEfCaKe 08-27-2002, 02:44 PM When u copy and paste into the new transparent file, u need to use magic wand, select the white, and delete it... this will remove the white, and leave the transparency... In photoshop, u can tell if its going to be transparent if u see gray&white boxes(default setting).. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
