10 AE Rx7 Turbo97sle 08-09-2006, 10:59 AM There is a kid around town that has this car and he gets it to shoot flames out of the exhause all the time. From what I know about the car it is stock. I was just wondering how he gets it to do it? L-Spec 08-09-2006, 03:48 PM Rotaries are known to backfire a lot :) The rotars are moving so fast at higher revs, that the gas is not fully combusted, but it still exits the exhaust ports and combust there and BOOM fire out the exhaust! From what I know anyways lol. It's easier to shoot flames out of a larger diameter exhaust pipe as well. drftk1d 08-09-2006, 07:38 PM its a rotary secret kekekeke naw probably he just took off his cats RX-7 Steve 08-09-2006, 07:47 PM Plutonium leak from the flux-capacitor! ghostrx7 08-18-2006, 09:04 AM i have an ae, and straight pipes is what makes big flames! i get like 2 footers out of each pipe..... sounds like an m80.. fb33112arx7 08-18-2006, 11:29 PM If you remove the cats and then drill a hole in the tail pipe large enough to fit a spark plug in, you can hook it up to some juice and get all those unburnt hydrocarbons to light up. I assume this would work really well with a rotary considering they don't quite burn as clean. drftk1d 08-19-2006, 09:36 PM but you don't even need to do that ever seen an rx7 hooked up to an egt gauge? the exhaust temps are hot enough alone. ghostrx7 08-21-2006, 11:36 AM ^true, like i said, i shoot 2 ft flames, no spark plug........straight pipes! Steel 08-28-2006, 07:18 PM YEah. Just dont make a habit of it when your not driving, unless you WANT to replace your bumper and tails. Automotive Network, Inc., Copyright ©2013
